Freddie100
New Member
Hi all, I am looking to fit a set of legs to my coastal cruiser and in need of some advice, I have read many forums and items but could do with further advice.
I plan to use a set of French legs I brought second-hand and seem in very good strong condition, they will connect through the hull with a single 18mm H/T bolt, on the inside of the hull I will bond probably with Sikaflex or similar adhesive a 460x150x25mm oak block to take the through bolt with washer and nut.
my thoughts are should I fit a oak block on the outside of the hull to take the through bolt or would a steel plate of say 150mm square fixed back into the wooden block, in using a block of wood on the outside this would increase the bolt length of 25mm or so maybe imposing more load onto the bolt
also should the legs which will be about 1400mm long splay at an angle outwards of the hull to increase stability when landed on the sea bed.
any thoughts appreciated
Freddie
Freddie
