mitiempo
I stand corrected. Only the dual sensing will draw .01 amps continuously as it is not only sensing from both sides but is connected to both banks at all times.
Normally one would hope that the engine start battery is pretty well charged so you can quickly replenish the juice used for starting, then within a very short time anyway the VSR will cut in and the house bank will be charging.
If the house bank has priority and is low it could be some time before the starter battery is topped up. The engine may not even run long enough for that to happen! Therefore make the starter battery the priority and then you know it's recharged. The short delay before the house battery is on charge is not important.
but you must allow for the situation in which the start battery is somewhat discharged. I''d say that both connections to the VSR must be able to safely handle the maximum alternator output.Were the house bank the priority the wiring could be considerably smaller as not much amperage would be going to the start battery to bring it up to full charge
