Tranona
Your example didn't mention wind from the wrong direction/too windy/not enough wind (Which I thought was pretty much expected sailing anywhere), but a tale of broken electronics and fatigue from steering.
A bit of string and rubber could have easily steered the boat.
You really do not want to understand, do you. The simple fact that if you set yourself a plan of action that can only work if you have a certain capability, and you lose that you are doomed to failure. I had a voyage plan that depended on being able to maintain 100 miles per day (in the right direction) irrespective of wind direction and strength (plus a contingency). So when you lose that capability and you have lost most of your contingency and the "worst" ie most difficult, part is still to come you have to re-assess. Of course if you remove the key constraint (time) then you have a different set of options.
It does not matter whether it is a failure of electronics (actually mechanical failure in this case) or a failure of the person, the outcome is the same. The option of sailing and steering would not have given the required level of progress to meet the target. That is basic commonsense.
And, actually a "bit of string and rubber" as you suggest would not steer the boat.
