penfold
Given the choice of having interscrew or sex bolt in my google search history I'll take the former.
That's why you wet out the mat on a board away from the job, no air, no drips.I've just spent days laminating foam beams under the deck, jammed in the forepeak of a 29 footer with epoxy dripping all over me. Laying on my back, wetting out 5 layers of glass per beam with a constant dab dab motion with my brush to push out the air as I added the epoxy was no fun at all.
Not in this case, unfortunately. I was working directly above my head. It would have (and did when testing) fallen down with the weight of the resin.That's why you wet out the mat on a board away from the job, no air, no drips.
It’s done now, but never again.Sounds horrid; I'd have tried to vac bag it, but that has problems of its own.
Paint the area you are laminating with epoxy and wait for it to go slightly tacky. The wetted out glass then sticks a little easier. You want absolute minimum epoxy. Just enough to fully wet the glass but no moreNot in this case, unfortunately. I was working directly above my head. It would have (and did when testing) fallen down with the weight of the resin.
I think I was just older than you when I had my op in 2015. Did you see the 2 hour Channel 5 programme on an aortic valve repair? Mine was of the mitral valve but I imagine it was similar; fascinating...... It probably wouldn't have been too bad at 20, or even 50, but I've just turned 71 and had open heart surgery a few years back.
So was mine, but that does sound interesting. I'll have to look it up.I think I was just older than you when I had my op in 2015. Did you see the 2 hour Channel 5 programme on an aortic valve repair? Mine was of the mitral valve but I imagine it was similar; fascinating...
I think it was transmitted on13 November 2018 and though I have a copy in my PVR it is not easy to extract (intentionally, I expect), and not visible on Channel 5 catchup.So was mine, but that does sound interesting. I'll have to look it up.
That's a shame - that was where I was going to look. Ah well, I'll live if I have to go without, which is more than can be said for the operation.I think it was transmitted on13 November 2018 and though I have a copy in my PVR it is not easy to extract (intentionally, I expect), and not visible on Channel 5 catchup.
I have a winter boiler suit that is well padded. One of my better investments. You deserve it.I kept an old cushion for jobs like that that entailed lying on the engine.
