Cantata
Can anyone recommend a boat gas fitter around here please (boat at Faversham)?
Boat certified is not the same as caravans.
One has bilgesHow is a boat installation different from a caravan one? (genuine question)
Gas heavier than air so any leak sits in bilge where as with a caravan it could fall out the bottom rather than build up. Both are at risk of leak / build up / ignition source / BOOM
Saw a boat in Jersey split from bow to keel and keel to stern by a gas explosion long time ago. Think one of the Nic 55s from Joint Services Gosport had a bad explosion back in the 80s
Tried one suggestion so far, they wanted 250 sailing tokens per day with no apparent concession even if it's only an hour or two's work. I don't think so.....
Several more leads to follow up. It shouldn't be this difficult!
Thanks all.
