JumbleDuck
Lots of people safely drop cradle pads every year.
It's not safe. They just get away with it.
That's a pretty stupid generalisation.It's not safe. They just get away with it.
Those who believe they possess the engineering knowledge and accurate cradle specs to safely drop a prop may nevertheless contravene the regulations of the marina. As a consequence the boat owners own insurance may be invalidated.
Here are some extracts from Premier's T&Cs:
"You must observe and perform these Regulations..
"You will be responsible for all actions, proceedings, claims,damages, costs, expenses, losses and liabilities caused byor arising from any damage or injury suffered by any personor to any property where it was caused by an act, failure toact or omission by You...
"Once your Boat is ashore You must not alter or interfere with any of the props, boat cradles or boat supports."
You know better than that.
Cradles have four legs for redundancy, so you can drop one.
I taught both structural analysis and 3D kinematics to engineering students for twenty years, and do not consider myself qualified to drop props. People who think it's easy simply haven't realised how complicated it is.
Blimey! What qualifications do you think boatyard blokes have?
Sadly, a lot of yards aren't very professional, so allow all sorts of home-made cradles to be used (rather like the one involved in the fatal accident). There's a marina near me which uses wooden props and wedges to "secure" boats for the winter. I'd only be happy with my boat in a properly-designed steel cradle.
Lots of yachts beach with two legs.
If you believe that, try taking a leg off a chair and tell me whether its still safe to use. Small wonder the yards make such an issue about it!
It is. However, it works best when the three legs are spaced equidistant around the edge of the stoolThe three legged stool is a time-honoured concept.
It is. However, it works best when the three legs are spaced equidistant around the edge of the stool![]()
The real point here is that cradles SHOULD be designed so that one leg at a time can be dropped safely, and antfouling completed properly. But I can still see that marinas / boatyards will want this to be done by their staff, not a random selection of owners.
This is probably a clueless question, but hey ho.
Is it not possible, when a boat is propped up, to put another prop alongside an existing one, then remove the first one so that where the first one was can be anti-fouled, painted, etc?
