BartW
Robg71; said:I was suprised how much extra materiel was required for the hull stiffening for the stabs.
well purely for strength, this is probably much too thick,
but the thickness is determined by the height between the stab flanges (78mm)
so we needed 78mm total thickness anyway.
some brands make this with a inner soft coring, (except for the circle where the flanges are pressing)
but in my situation, (surfaces not really flat...) I preferred a solid plate of GRP or Epoxy
the extra weight doesnt make a difference on the total scale
the outside layup is needed for making height for the fins not to touch the spray rails nor the chines,
idea stolen from San Lorenzo,
other solutions, with inside layup only,
would require cutout from the spray rails, and placing the fins more towards the keel / center of the hull bottom
with my chosen solution, the electric fins can rotate 360°, never practically needed, but just in case, for maintenance or ...
