Dunx
I am looking to instal 2 solar panels on our boat. One is 120W the other 80W. The sizing and semi flexibility is due to fitting them on the garage and pilot house roof. I intend to use a Victron 75/15 charge controller.
12V solar panels charging kits for caravans, motorhomes, boats, yachts, marine
The panels operate at the same voltage and I understand that due to their differing output they should be installed in parallel for best efficiency. Due to location some shading is also inevitable. Each panels will likely have their MC4 connectors removed and the cables brought through glands to a fuse (10amp?) for each panel and then on to an adaptable box for connection before the charge controller. Should any further switch option be installed ?
I have read loads of posts on here but remain confused as to whether it is necessary to instal a blocking diode on each panel. If so is it best to re-terminate the cables with MC4‘s and use MC4 propriety diode connectors or to use a “Schottky diode” on a termination block inside the adaptable box? I know little about electronics so could anyone recommend suitable diodes if they are needed?
