Trevelyan
With no water pumping, I pulled the impeller to bits - which was fine.
After trying to blow into the pipe to the engine block (from the impeller), I found no airflow - i.e. blockage in engine!
I then blew into the pipe from the engine to the exhaust elbow, with no luck.
I put a foot pump on it, and after a few good pumps got some flow.
I have used an old outboard fuel line/primer to pump hot water through the block ("backwards"), does anyone have any advice on any chemicals I can add to help clear out salt deposits and other crud? Obviously I have cleared one path through the engine, but concerned other waterways could be blocked.
The engine is a Vire 7 - the cooling water goes through part of the engine which is ALUMINIUM, so I need to be careful?
Cheers for any tips,
Trev
Trev
