shanemax
Just a thought......... 0.01 bar must have started the sinking of the Titanic.
When I ran a charter yacht/sailing school part of the briefing was:
"If anyone lets the end of a halyard run up the mast they have automatically volunteered to go up and retrieve it"
The same idea could apply to toilet blockages - it should encourage enthusiastic pumping.
true, or therabouts, but ts hard to hold back water coming through a huge tear through the hull, easy to through a round pipe..Just a thought......... 0.01 bar must have started the sinking of the Titanic.
Looks like an Artery before a stent or bypass............. happy daysBoth sides can and often are affected by build-up. If one side was badly clogged, the other side won't be much better. While you are at it, clean the anti-syphon as the valve often gets clogged as well.
If the pipes are old, better to replace them than bang them clean. New pipes are softer and easier to re-fit.
You should be concerned about your stuck open sea-cock: it needs to be changed. Loo outlet seacocks are particularly prone to this. Do not think for one moment of doing away with it! If you are a plumber and not worried about a bit of water, it can probably be changed afloat. First check if the sea-cock can be turned very slightly without disturbing the skin fitting. If so you are in business. Swim down and knock a bung into the outlet to stop the worst of the flow. Then cut off the pipe (easier than trying to pull off), unscrew the old sea-cock from the skin fitting, and fit a replacement using PTFE tape. Do this quick and you won't have more than a cup or two of water come in. Open the new cock, poke out the bung, slam it shut and refit the pipe. Best is two hose (jubilee) clips on underwater fittings.
Old toilet pipe, cut off at the seacock. Note the bung and hammer.
