Richard_H
Hi everyone
Recently drained a small amount of water from the filter cannister on my Volvo MD2040 engine - by way of the small plastic key on the underside of the Delph aluminium cannister. All in all about 20ml of water came out with about 100-200ml of fairly cleanish diesel before it stopped emptying.
My engine always starts very well first time, is in very good nick and is generally a good clean runner! However when I started it this time after draining the fluid, the engine cut out after about 30 seconds running and needed a restart via ignition key etc. After that small hicough she has been fine. Question is should I now need to bleed the whole system, pump, filters etc., and if so which end of the engine do I need to start from first. I always thought draining the water from the filter shouldn t cause any air problems. Appreciate learned comments.
Kindest reagrds
Richard H
Kindest reagrds
Richard H
