DickB
My 48' yacht is now 18 years old so I figured I needed to check the moisture levels and get rid of the 18 layers of antifoul. I did consider doing this myself either using chemicals or scraping, but opted for getting it sand blasted. (My yacht is based in Gosport and is now sitting in pride of place at Trafalgar Wharf).
This is a scary process since the blasting could easily blast away the gel coat. After doing a LOT of market research by speaking to a LOT of folk about who was best I ended up employing a guy named Paul Baker. He uses sand and he has a huge towable compressor and all the gear to do the job.
I originally wanted a guy who uses the Farrow System as I understand it is less fierce but the company who used it (ARC) have now dissolved (!) and the machine has been taken over by a company called "Black & White Blasting". After arranging several dates to do the job (weather delayed us) the guy basically seemed to disappear and didn't answer the phone or reply to emails. I never found out what happened there. Very odd!
Anyway I asked the marina and they recommended this guy Paul Baker who has actually done a first class job. No damage the gel coat and she now has a beautiful white bottom! You can see her from the A27 passing across the north end of Portsmouth harbour right by the Drystack.
Anyway if you are considering this job I would recommend this guy. His email address is "paulnbaker@gmail.com" . He is quite a character and talks the hind legs off a donkey but he was not expensive and did a good job.
pm me if you want more detail...
cheers,
Dick
ps - Just a happy client... Nothing else!
cheers,
Dick
