FairweatherDave
Somewhat rashly I decided to follow Lavac's advice and detach the heads inlet and outlet pipes to my 37 year old Blakes seacocks. This is order to drain down the pipework. This is while afloat. It was then I discovered my seacocks don't close fully....:disgust:.... So what has been keeping my boat afloat has been sound pipework with a section well above the water line. So I reconnected the pipework. I would add that at the start of the season I serviced the seacocks with Blakes grease and the levers both moved nicely.
I have read here
1. At least one person found their lever had to be at something like 100 degrees to fully close (this is a possibility I could investigate further) but really?? surely 90 degrees to close. Any comments?
2. Some people (a small number) have serviced their Blakes seacocks while afloat. I am thinking I could do a quick dollop of grease on the cone whilst using a bung as a short term measure (In much the same way as you remove the log wheel for cleaning and put a blanking plate). I would leave the grinding paste more serious service until I was dried out or ashore. I would like my seacock to be properly closed. Is it likely a good dollop of grease would help. (I have read that the heads outlet seacock is particularly prove to pitting).
It seems to me that most people service seacocks ashore but then don't test them as they have got tricky pipes to remove and the consequences could be serious, so it is the success of the pipework that could be keeping a lot of people afloat. ( I have read about people pressure testing from the inside with hosepipes?)
Apologies for bumbling through this subject but this is the first time I have had to think hard about my Blakes.
Any comments welcome.
The short version of the question is is it reckless to service a Blakes seacock whilst afloat and is a good dollop of grease likely to sove the water ingress?
I have read here
