Blakes seacock again
westhinder
15 Feb 2003
Belgium
I have had to remove a Blakes seacock from the hull, which went without problems, but what do I use to bed it with?
When removing the seacock, after 12 years in place, the bottom plate was covered in a soft, slightly sticky yellowy goo, which appeared to be a sort of grease. It was easily removed with cleaning petrol.
So what do I use to bed it on the hull? Try grease again? Sikaflex, which might prevent easy removal in another 12 years' time? Anything else? I have to add that due to the place where it is fitted, I will not be able to get leverage under the bottom plate with a screwdriver.
Many thanks
Thanks folks.
Will I be able to remove polysulphide again,
Yes. It will stay rubbery and the joint can be broken fairly easily.
Polyurethane (such as SikaFlex) is as you know a powerful adhesive, and very useful in the right places.
Silicone forms a very pliable and long lasting seal, but does not adhere so well to the surfaces which may be a problem if there is any movement.
