Bobobolinsky
It's also described in Fred Bingham's "Boat Joinery & Cabinet Making"
Robin
Robin
I've just found the book I read it in.. its the west system "fibreglass boat repair and Maintenance" the refer to installation of a new teak deck but as far as I can see re-installation will be just the same if your teak strips have some substance left. They talk about two methods. The first refers to teak strips 3mm thick bonded and caulked at the same time by epoxy coloured black with graphite. They then also talk about teak strips 19mm thick with which they do refer to movement of the wood being more at the top than the bottom so with wood that thick they recomend bonding to the deck with epoxy but caulking with an appropriate compound to allow for the movement. In both methods they talk about calmping the strips down with sheet metal screws temporarily between the strips which also act as spacers. With the re-installation I am thinking I will probably use the original screws to clamp the strips during bonding but once cured remove them, fill the holes with epoxy and replace the teak plugs. My strips are( bearing in mind I don't yet have the boat!) 8-10mm so I would probably go with the poxy gluedown with caulking filler. I shared your concern over wood movement but the West people seem to know their stuff ( as I guess they should!!) so thats my plan. I would again stress that I've never actually done it but have worked quite a bit with epoxy. If you want any further detail of what it says in the book please give me a shout... good luck Iain
Often teak has to be forcibly removed by chisel or a router.
No kidding
ooh er!! I think I'll just go with removing screws and filling holes with epoxy to try and stop any further water getting into core... damage limitation!!
I know exactly how you feel
However, you have to seriously consider your long-term plans for the boat.
If you plan to keep her, your course of action may well give you another few years, but eventually the whole deck will have to come off. Be under no illusion.
For a few years we did exactly what you're planning to do. This did not mean the problem went away, it just became less obvious. There's the moisture already trapped underneath to consider - the rot will continue - maybe more slowly, but no less surely.
Teak decks >15 years are a ticking time bomb. Will you be holding it when it goes off?
I love our boat; but if I had known what I know now... If there's ever another boat -> no teak decks!
All I can say is... what a bloody stupid way to build them in the first place!! I'm not a boat builder but I know enough to know that if you put holes in your cored deck then eventually water will get through.. I'm sure they could have found a better way!! Anyway its been great to hear all the advice on here.. cheers Iain
Well, all I can say is what a great set of replies. Not sure if it solves the problem but sure gives lots of food for thought during those long winter evenings.
I have a German acquaintance here in my marina who worked for Rassy then for the company when they bought out Harry Hallburg to become Hallburg-Rassy.All I can say is... what a bloody stupid way to build them in the first place!!
What he tells me is truly amazing. For two years HR designed yachts without teak decks for all the reasons given here - they made no practical sense, were too heavy too high up and had a limited life with damaging side effects - for a horrendous investment in time, money and a material that would be better left in a SE Asian rain forest - except that these days it is usually an inferior product force-grown in plantations all over the tropical belt.
But you know what? No one wanted to buy a quality yacht without a teak deck! HR had to keep adding a teak deck purely on yachting snob grounds until they gave up and made it a standard specification.
He used to come over to my boat while I was sweating (here in Italy I mean that most literally) over my mouldering teak deck both last year and this, trying to delay the inevitability of tearing it all off and laying something more sensible. He would sympathise and reminisce (he was at the yard when my boat was built) about all the horror stories he was privvy to.
So, don't blame the boat builders, screwed down planks were the only way to keep them stable at that time. Instead, blame the consumer who would only accept their boats so adorned.
