lanerboy
Hi All
As you probably know I have just replaced all the toilet and holding tank pipe work due to a terrible smell, well the good news is the smell has now gone but I still have a small problem. When I removed the old pipes they were all difficult to get off the old fittings etc etc EXCEPT where they fitted onto the whale 3 way diverter valve, when I took the old pipes off the valves they just pulled off with very little effort.
These are the valves I am talking about which are OE fitment on my phantom 40
So once I had fitted all the new pipes I tried to fit the last 6 ends onto the existing valves but no matter how hard I tried I could not get the new pipe to stay on the diverter valves they literally just fell of if I turned my back even with 2 jubilee clips on as it was before.
I think it has something to do with the new pipe I have used as this has a steel coil built into it which is making it difficult to fit onto the valves. I have fitted it onto all the other fittings with no problem at all it is just where it goes onto the valves
This is the pipe I have fitted to replace the old stuff
So I have now purchased 2 new valves made by Jabsco same as in the picture below
I have bought these as they have a ribbed section on the part that fits into the pipe so I am hoping I can hold the new pipe onto these new valves with the help of the ribbed design
Just wondered if anyone else has ever had this problem as it is a bit worrying due to the fact that if it falls off when I am not on board then obviously the boat could sink as the sea cocks would be open
All suggestions much appreciated yet again
cheers shawn
cheers shawn
