actionoptics
exit pupil changes with age
Ø Exit Pupil refers to the diameter in mm of the circle of light visible at the eyepiece. The larger, the brighter, but our ability to fully utilise the binocular exit pupil, diminishes with age.
AGE* DAY* NIGHT
20* 4.7 mm* 8.0
30* 4.3 mm* 7.0
40* 3.9* 6.0
50* 3.5* 5.0
60* 3.1* 4.1
70* 2.7* 3.2
80* 2.3* 2.5*
Myopic or short sighted, and you can add a bit
Hyperopic or long sighted, you have to subtract a bit.
Source – Hebditch May ‘47
I don't understand the reference to a large exit pupil being able to
compensate for a mild mis-alignment.
Any mis-alignment will cause eye strain or headaches.
I have two binocular collimators in my workshop - one to use whilst
actually moving the prisms into the correct positions and the
other to make sure the adjustments are spot on.
The difference between almost-aligned and spot-on is noticeable.
AGE* DAY* NIGHT
20* 4.7 mm* 8.0
30* 4.3 mm* 7.0
40* 3.9* 6.0
50* 3.5* 5.0
60* 3.1* 4.1
70* 2.7* 3.2
80* 2.3* 2.5*
