Lomax
What sort of waterproof relay are you going to use with it?
Haven't decided yet, but it probably won't be waterproof, but rather mounted in a waterproof enclosure. Small IP68 enclosures don't cost very much and allow more flexibility WRT relay board and number of input/output connections. This will be mounted next to each pump, some way up the side of the hull. From this there will be connections to the pump, the sensor, the on/off/auto switch with running indicator, and the on board computer monitoring system. Ideally the board should provide an "on" delay in addition to the "off" delay, but I haven't been able to find one that does this off the shelf (yet).
