bluedragon
How many of us have dry boats and an electric bilge pump that has never been used or tested? Thought I'd try ours today. Johnson 120L/min pump. Got the hose down below and started to fill the bilge to see what would happen! Some surprises...
Firstly the pump doesn't have a float switch and is only functional manually. Apparently the float switch is an "extra"...can you believe it!
Second issue is there is so much back pressure that water squirts out of the hose attachment back into the bilge in spite of two good hose clips. I've checked the outlet hose and it seems clear, but there is a (suspect) non-return valve that although it seems to work, I think just puts too much flow restriction into the system. The installation instructions for the pump don't mention the need for a one-way valve at all...so do I need one? The outlet is well above the water line and perhaps the pump itself has such a valve built-in anyway? It's not clear to me. Is this an essential device for all bilge pumps that I leave out at my peril?
Anyway, thanks to the good 'ol hand-operated Whale pump, the bilges are now dry (and clean!). But I've got to get this Johnson pump working properly. At the moment it's close to useless.
