Yellow Ballad
One of the things I have planned for the winter is fitting an electric bilge pump (I've finally succumbed). I'm just thinking ahead of where to put the outlet. I have a manual pump that is fed to the cockpit drains but this backfills the cockpit when used and if the fhit hits the san and I'm using the pump I would rather not share the cockpit drain as it's restricting one of the other from doing it's job. So I need to fit two outlets, one for the manual and one for the electric pump, makes them symmetrical then...
Now do I fit them near the centreline under the stern (behind the cockpit drains) so I can make a high loop and then down or the side of the hull but without a high loop (but I could cross the hoses so high when heeled). My only thought in the center would be in a following sea it could possibly allow water into the hull. Thoughts, suggestions all welcome.. I'm all ears.
Pic for reference
Pic for reference
