rogerthebodger
Any 12 volt explosion proof exhaust fan will be OK to remove petrol fumes from the engine room
Ignition proof is the key Roger, as you know. If the fan is not ignition proof then it's more dangerous than not having a fan.Any 12 volt explosion proof exhaust fan will be OK to remove petrol fumes from the engine room
Absolutely.. also if the fan is to be on all the time, then it needs to be continuously rated. Some of the “budget” fans are not meant to be on all the time and in some cases (unlikely but not impossible) could overheatIgnition proof is the key Roger, as you know. If the fan is not ignition proof then it's more dangerous than not having a fan.
That's all I know. It's one thay came on a new to me boat. Just a blower.I didn't ask how it was fitted, i asked which fan. Never mind, i was merely trying to be helpful.
What are you hoping to achieve with your bilge blower? Petrol vapours are heavier than air so will accumulate low down, thus any ventilation needs remove vapours and air from the bottom of the bilge. Industrial gas fired ovens are required to have a prepurge of 5 volumes as part of the start up sequence. This is done by opening all the dampers and putting the combustion air fans on high flow, and in practice takes only a few moments. The logic behind the 5 volume requirement is that if the oven was 100% full of gas (i.e. no air at all) then a 5 volume purge will, in theory, reduce the concentration below 5% (LEL of natural gas). Fitting a small fan extracting from high up will in practice not achieve anything.
To remove any flammable gasses. This one is fitted with the duct low down at bilge level. Well maybe 4inch off the bottom.What are you hoping to achieve with your bilge blower? Petrol vapours are heavier than air so will accumulate low down, thus any ventilation needs remove vapours and air from the bottom of the bilge. Industrial gas fired ovens are required to have a prepurge of 5 volumes as part of the start up sequence. This is done by opening all the dampers and putting the combustion air fans on high flow, and in practice takes only a few moments. The logic behind the 5 volume requirement is that if the oven was 100% full of gas (i.e. no air at all) then a 5 volume purge will, in theory, reduce the concentration below 5% (LEL of natural gas). Fitting a small fan extracting from high up will in practice not achieve anything.
You have to be 100% certain it is ignition protected. If not, rather than extracting fumes it will more than likely ignite them.That's all I know. It's one thay came on a new to me boat. Just a blower.
Petrol fumes coming off a warm engine are often warmer and lighter than (ambient) air.What are you hoping to achieve with your bilge blower? Petrol vapours are heavier than air so will accumulate low down, thus any ventilation needs remove vapours and air from the bottom of the bilge. Industrial gas fired ovens are required to have a prepurge of 5 volumes as part of the start up sequence. This is done by opening all the dampers and putting the combustion air fans on high flow, and in practice takes only a few moments. The logic behind the 5 volume requirement is that if the oven was 100% full of gas (i.e. no air at all) then a 5 volume purge will, in theory, reduce the concentration below 5% (LEL of natural gas). Fitting a small fan extracting from high up will in practice not achieve anything.
Just had a look on the Jabsco site, they state fans for fuel fumes in engine room, which should mean they are ignition protected, but they make no mention of it.Paul I had a look at the info of the Jabsco blowers but I cannot see it that are ignition do you have any info on that fact.
I have 2 jabsco axial fans feeding cool air into my diesel engine room mainy to cool the engine with shut off valves to shut off air in case of a fire
That's only remotely true after the engine has cooled to match its surroundings.The petrol fumes and the surrounding will be at the same temperature and will sink into the bulge
Ambient air temperature is another matter and is not in the engine room
In practice, hot smelly vapour-laden air rises off a petrol engine.
Oxygen is a bit denser than nitrogen.The vapour density of petrol is about 2.5 time that of air
And yes hot air does rise compared to cold air but we talk about the RD of petrol vapour at the same temperature as the air in the engine room
If you wish to look at the how the RD of petrol and air change with temperature
Its all depends on th relative density of air and petrol vapor
Try breathing from nearer the floor....
