aitchw
My recently acquired 16' triple keel (long keel with small bilge keels) Seasafe has no access to the bilges. There appear to be just two full bulkheads which go down to the bottom of the central keel, one in line with the start of the foredeck and the other at the cabin entrance. There is ballast (probably concrete) which I assume is located only in the central section under the cabin sole. When I rock the boat fore and aft on the trailer I can hear water sloshing around. I need to cut a hatch in the floor big enough to at least get a hand bilge pump pipe in but better, big enough to get my hand in to sponge out.
Problem is what to use as a hatch fitting. 4" dinghy hatches won't take being stepped on repeatedly and are not designed to cope with pressure from the inside. Yacht hatches which might do the job are big and expensive.
Anyone any ideas about what to use that's affordable?
I have no doubt the builder intended these compartments to be watertight but I don't think any boat of an age is likely to be completely dry. There are no hull fittings which go through the hull except for the rudder tube and the hull looks sound, no cracks or damage. The window seals have let in water for a long time (about to be replaced) and the boat has had a lot of standing water inside until I took her on a couple of months ago. These are the most likely sources.
Any helpful pointers to dealing with this would be appreciated.
Thanks.
Howard
Thanks.
Howard
