noelex
Like Thinwater, I am struggling to understand your logic.You still miss the point. I am not asking about ultimate holding power - how many more times do i have to say it - that is obvious. I am asking for evidence that FOR THE SAME PULL a larger anchor generates greater holding power. That table simply shows a bigger anchor has higher POTENTIAL holding power.
I really cannot see why you have so much difficulty with this question - because you are claiming that it does.
If we take the Spade anchor as an example, the table shows that in the test substrate the UHC (ultimate holding capacity) of the 6kg Spade was 120 kgf while the UHC of the 15kg Spade was 420 kgf.
This means if a boat is exerting a pull of less than 120 kgf either the 6kg or the 15 kg Spade would hold. If the pull exceeds 120 kgf, the 6kg would no longer hold and the boat would be dragging while the 15 kg would still be holding providing the force does not exceed 420 kgf. Simple.
So, for example, if the boat exerted a pull of 300 kgf and had a 15kg Spade the anchor would be generating more holding power (at least 300 kgf) than if it had a 6kg Spade (this would be generating less than 120 kgf, probably a lot less because the anchor is moving and not digging in correctly).
This is a simple example where FOR THE SAME PULL (or more correctly the same force on the boat) a larger anchor generates greater holding power.
