Beta Marine with TMC 40 gearbox Fluid ?
graham
Only information I can find is to use automatic transmission fluid.
Is all ATF the same or are there different grades?
Is your gearbox a TMC 40?
TMC40 on a Beta 25. Before that a Hurth50 on a Beta17. Both OK on Dexron 3. I thought Dexron 2 has really been superceded but I think I'd be happy using either.
Beta just specify ATF, I think they'd be more specific if it mattered.
Don't confuse ATF with transmission oil!
Thanks for the replies.I have ordered a litre of Castrol dexron 3 ATF .Surprisingly the gearbox only takes 0.2 of a litre so should last 5 years if I don't spill any :-)
Thanks for the replies.I have ordered a litre of Castrol dexron 3 ATF .Surprisingly the gearbox only takes 0.2 of a litre so should last 5 years if I don't spill any :)
Was that just a double post or do you now have 2 litres of ATF coming ? :)
First it wouldn't post at all then 2 appeared. I don't really want enough for 10 years!
