Lutra
Hi all, I’ve got a problem with my Beta 16 AVB control panel.
As soon as I turn the battery isolater switch on, the alarm sounds, green light, battery and oil lights illuminate, tachometer illuminates. When I put in the key, it makes no difference.
When I turn key to run, alarm gets louder, battery and oil light get brighter. Green light and tachometer light go off
When I turn key to start, engine starts and runs ok. All red lights go off. Green light and tachometer stay off. Engine is charging at14.4v.
Engine stops as usual with the button. After stop green light comes on and alarm sounds.
I’ve checked wiring harness 11 pin connector and also wires and plug at alternator look ok too.
I’m guessing might need to check panel wiring, relays maybe? Grateful for any suggestions
