bluerm166
I've just refitted the wired connections having completed a new fascia after the plastic original crazed and fell to pieces.
I labelled all the wires or groups when disconnecting and together with the Beta Wiring diagrams got everything happily back in place.
Except I find I have the negative return from the Faria hours gauge ( not a beta item) with no proper place to attach it,ie no vacant female spade.It terminates in a male spade which has been bent as shown.
Presumably this was hooked in to one of the spades for the lamps or possibly the stop button .
This was added at the same time as the original install and has been running happily for years ,when the engine/alternator is on.
Would be grateful for advice as to which point I can connect this to to complete the circuit.I can change the terminal fitting if that's necessary but I am not a 'solderer' .
