PetiteFleur
On my Moody 33, I know that the P bracket is not aligned to the prop shaft. I've removed the prop, Stripper and anodes and there is about 3mm vertical movement in the cutlass bearing and just looking at the wear pattern, the P bracket is not aligned correctly with the shaft. I did notice this several years ago when I re-engined when it was it obvious it had been like it from new. So am thinking about re-aligning the P bracket. My first thought would be to pack out the P bracket with washers between the bracket base and hull. Once aligned correctly, with a new cutlass bearing, I would tighten up with suitable mastic, say Sikaflex 291 which should stop any potential leaks. As the bracket has 4 bolts holding it down, I should be able to just put washers on the fore or aft ones to level up the shaft. Perhaps a packing strip of plastic would be better than washers, maybe the sort builders use?
Is there a better/easier way or should I just accept renewing the cutlass bearing every few years? This will be the 3rd time I will have renewed it in 13 years.
