RichardS
N/A
What do you think causes water to move apart from the rise and fall of tide?
Ah yes ..... the movement of those streams of tidal water. What should we call those, one wonders during these times of lock-down?
Richard
To help you, can you re phrase the question?Ah yes ..... the movement of those streams of tidal water. What should we call those, one wonders during these times of lock-down?
Richard
Rumble of the rumba.Is it the beat of the samba?
I suspect that most on here are "on message".To help you, can you re phrase the question?
And a happy one to you too.I suspect that most on here are "on message".
PS It's only a bit of fun with words to lighten up a lock-down Easter Sunday.
Richard
(g) + a cold tinnyYou are dossing in the cockpit when anchored and decide to find out the speed of the tide.
Do you...........
(a) Good enough to guess.
(b) Finally get up watch flotsum and guess
(c) Go to the bow, spit and then time and distance.
(d) Have a super sensitive log that will enable you not to leave the cockpit
(e) Ask a likely looking local passing by
(f) Find the nearest diamond and estimate
(g) None of these things. I'm not bothered
(h) Waiting for the latest gizmo from NASA to do it.
A g then ?None of the above. I'm not bothered.![]()
Richard
Not sure i understand .
Why do you want to know the speed of the tide?
Do you mean
If the second then a log- super sensitive or otherwise wont help.
- tidal stream as some have suggested or
- rate of vertical rise/fall in mm/min?
if the first then why "super sensitive" ? Normal log will tell you to within 0.1 knots.
Its easy where i live. At springs the tidal stream in the channel can be up to 8 knots.
I can motor at 6.5 knots so if i am motoring against the tide and GPS speed is 1 knot and i am going backwards with respect to shore marks, then i know the tidal stream is 7.5 knots!
Thank you John. I had begun to wonder whether I was on my own.Not sure i understand .
Do you mean
With music too.
