eddystone
Generally I've tried to use plastic scrapers and bits of wood to remove barnacle/tube worm encrustations from bronze prop and stainless steel shaft but these can only go so far, especially on fiddly bits like teeth of the rope cutter. I'm wondering whether it's OK to use the sharp end of a chisel, carefully, especially a round section one I have, and/or a wire brush? I would plan to finish off with progressively finer grades of wet and dry. I will be anti-fouling prop but not the shaft - I'll probably use udder cream on that.
