RJJ
If you really are at nil experience other than CC...I would want to learn more, from somewhere, before setting off as skipper. DS course is one source of knowledge. You could consult books, YouTube, and you could (I strongly recommend) do a little dinghy sailing.
The latter is how many of us cut our teeth. It has great advantages in learning how all the essentials of boat balance, sail, foils and steering work together - because you are in charge of all of them in an a more responsive, connected way. You can do a hundred tacks/gybes in your laser or Wayfarer in less time than you do five in your yacht. You can capsize it. You can crash it and a repair is unlikely to run to three figures. You can do Man overboard drills, heaving to, picking up moorings on your own all day (without having to bore your yacht crew). And it's fun.
Dinghy sailing is generally associated with picking up core sailing skills of clise-quarter boat handling, manoeuvres, sail trim, wind awareness at greater speed and lower cost than yacht sailing.
Tom Cunliffe's most recent Day Skipper guide may be useful. Compared to many such books it (1) presents your first steps as skipper in an informal realistic way (2) encourages you to understand from the outset that there are many ways to do things, with pros and cons, and your job as skipper is therefore not to only to adopt doctrine but to understand it and apply with discretion.
Personally if your CC is literally all you have, I wouldn't be going alone just yet. I would want to get some skills from somewhere else which could be (but isn't necessarily) an instructor. Own boat tuition sounds wise; sailing with chums is also good. If you let us know where you are,someone might make you an offer.
The "meta-advice" is that (1) you must never stop learning (2) you accept great responsibility to assess your own capabilities (and crew, and boat) and make decisions accordingly. DS qualifies you to sail "in familiar waters by day"...but only actual experience and judgment enables you to decide whether to go out in a choppy F5 with less experienced or novice crew.
Good luck!
Good luck!
