Hacker
We clean our brushes out in 3 consecutive acetone baths. They get reused usually at least 4 times with no problem.
Cheers for the link, i've been looking for a replacement epoxy since reactive resins went tits up, what would you recommend on their list for filleting and laminating or is it a case of getting separate products by application, the prices look great too!destroyer dinghy most likely
I used approx 60lt of epoxy during my 43ft ply mobo rebuilt over a period of 4yrs.
20lt seems a bit much, no?
I've used a local co which is strangely selling 95% of its wares abroad. Have a look maybe interesting
www.fibermaxcomposites.com
cheers
V.
I've cleaned brushes used for WEST and SP with a high tech formulation known as 'Fairy Liquid'.Does water-based mean you can rinse out your brushes etc with warm water? Seems quite a big advantage.
have to go through my notes (somewhere...) but most of my work was scarf joints in 15-18mm marine ply and other "glueing" together with screwing panels/things down to frames.Cheers for the link, i've been looking for a replacement epoxy since reactive resins went tits up, what would you recommend on their list for filleting and laminating or is it a case of getting separate products by application, the prices look great too!
Roger
When i used solvent epoxy for my boat refurb i used cleaner for the brushes ( still have some) but obviously not rollers. I also had a special hand cleaner. I could not clean rollers but as they were only 4 inch this was not a big dealyep, with solvent based, you practically throw away the kit you've used each day[hopefully only rollers, but if you use any brush, forget about reusing it]
Yeah no worries, know what you mean about being flamed on here, christ i could write book on it. I saw a UK address on their site and thought they were based in UK, if you could ask anyway what he recommends for Sheathing / Filleting & bonding that'd be great. Gave up on Wests years ago.have to go through my notes (somewhere...) but most of my work was scarf joints in 15-18mm marine ply and other "glueing" together with screwing panels/things down to frames.
I used A LOT of 481 iirc as it's the cheapest general purpose one they have for soaking mat over ply.
I tried various for glueing and tested them with microbubbles, and some other powder looking substances he's selling.
I generally only had problems (as in creating nice smooth paste) when I tried to create thickened epoxy to fill gaps and glue things together, but it worked and the living proof is that the boat is still floating after 5yrs
I also used some higher cost ones 93something iirc diluted with isopropyl to soak old timber (iroko in my case) and prepare before glueing things on it. sort of custom CPES
DISCLAIMER: that was a diy restoration project done here from 2011-15 (finishing work still going on) I've been "flamed" occasionally in here that I'm not doing things properly, so I'm not to be hold responsible for what you do, nor have I any interest in trying to prove that what I've done is right - don't care, life's too short!
Guy is 5m from Volos where I live, know him personally (after all these years) happy to ask something specific, or see if there's a cheaper option to ship liquids up there. Just let me know.
cheers
V.
Why would one give up on West? The product works & I found the support excellentGave up on Wests years ago.
Its beyond useless to work with in cold temps unless you want big bills heating the stuff, super expensive and requires a lot of processing in anything other than perfect conditions certainly compared to other brands i've used. Wests is the epitome of what large advertising and marketting campaigns can achieve like sika et al.Why would one give up on West? The product works & I found the support excellent
I recently built a Danny Green Chameleon but only managed to use about 65% of the epoxy on the materials list.
I should have bought 1/2 of the epoxy (from East Coast Fiberglass supplies) then the rest after the first lot was finished.
Ive now got a load of epoxy way past its use by date.
Plank
I used it through 2 winters with great success & found no problems whatsoever. Great product.Its beyond useless to work with in cold temps unless you want big bills heating the stuff, super expensive and requires a lot of processing in anything other than perfect conditions certainly compared to other brands i've used. Wests is the epitome of what large advertising and marketting campaigns can achieve like sika et al.
