Trevelyan
Hmmm so I have a bit of a blind spot on Jeanneau.... which are the good ones to look out for please? We looked at a Sun Odyssey 39i which had an amazing cockpit, down below was ok (if a bit flat pack kitchen feeling on the "wood"work edges. But I wasn't convinced by the upper shrouds coming down to the edge of the hull (how does this affect sheeting of headsail/limits size?) and it just felt like it was squirming around in the wind lots - the keel and the mast look quite far forward. Am I imaging things, or....The choice is probably quite limited in UK market. The boats which will be about most will be Bavaria,beneteau,jeanneau and Hanse. If looking more up budget then x or Arcona. You will find the bow cabin on the smaller arcona tight compared to 410 type. I assume you have ruled out Hallberg and rustler as not sporty enough. If looking I would be tempted by Dehler as as starter . A Dufour is not that quick I suspect but if looking at37 ish they have big galley and fridge but the forecabin is offset which might not appeal . A dream boat for a racer is thought to be an arcona but at a price. You might also consider where you want your mainsheet traveller which might impact choice. If moneyno object an xc42
Re mainsheet traveller, I guess in the cockpit better for sailing, out the way better for children... think I'm open to either arrangement unless convinced differently!
