Bennett Trim Tab Pump
julians
11 Jun 2006
You've probably already thought of all these, but I'll list them anyway. I have no specific knowledge of the bennet trim tab pump (had one on my old boat, but it was fine) , just coming up with generic things that could cause you issue
-low battery voltage, either through worn out battery or (maybe more likely) corroded connections?
-maybe corrosion inside the motor itself on theelectrical connections , or buildup of dust? Maybe it just needs dissasembling and a clean.
- worn pump motor itself, maybe worn brushes?
- a seized bearing on the motor leading to increased friction?
