Anders_P42
Been a while since I've updated this thread. Just past two years ownership, 175 hours on and still enjoying every minute on board.
Last year I had a small accident, not with the boat, I slipped down the stairs to forward cabin. I'll admit I was slightly under the influence at the time, but the main issue was I had turned the salon lights off before walking down the stairs. Very lucky I didn't break right arm, still have the scare from the slice of skin I took off on the edge of the steps.
Earlier this year I decided to add some under step LED's. I did some research and decided on these waterproof LED's covered in Silcone, from a company based in the Isle of Man. Phone number on their website and happy to talk, which is not always the case with LED suppliers. Seem a decent product inc three year warranty.
http://www.litewave.co.uk/prod_cat/...licone_396_constant-current-led-strip_78.html
I bought two 1m lengths as I could cut and use both pre-wired ends. I decided to protect them with DC-DC regulator, this one supports 8-40V input with 12V 2A output, more than enough for a few LED's.
I decided to mount the regulator in here, away from any possible Hydrogen gas that might be in the battery compartment, just in case the regulator failed and the fuse didn't do the job.
Fuse in holder is the output side of the regulator, I use a spare fuse on the main distribution board to power the regulator.
The LED's are adhesive backed, but I also used some superglue along the edge of the LED to make sure they weren't coming off.
I hid the on/off switch here, I can reach this from the bottom step. It's to the left of the fridge (for those who own one).
Final result, a lot of light from two LED's per step
