Paul366
When bending on the Head Sail on a Fractional rig, is it easier for the head sail to slide up the groove in the foil with either; more backstay tension? or less backstay tension?
Shouldn't make any difference, however if you are a "set halyard tension in the spring and forget" type sailor, then set the tension with the backstay tight. Otherwise you risk over stretching the luff when you apply backstay.When bending on the Head Sail on a Fractional rig, is it easier for the head sail to slide up the groove in the foil with either; more backstay tension? or less backstay tension?
