Bending 1/4" copper fuel/gas pipe
fredrussell
24 Mar 2015
I'm about to plumb in my Taylors 079D heater. In the past I've always put bends into gas pipe using my bare hands. Once or twice in the past though, I've caused kinks doing it this way. Does any one know a method for bending these small copper pipes without the risk of kinks?
Pipe is 6.3mm or quarter inch OD.
When installing my microbore central heating, I used a cheap plastic former from a plumbers merchants. Very effective and 100% success. I also used it for my boat gas pipe. I have 6 and 8mm sizes. Unfortunately, I can't seem to find them for sale anywhere on interweb.
simple way is find a piece of tube approximate of the radius of bend required and wrap the tube around it, scaffold pipe is good. Used to make nice radii in brake tube with this method.
I have a set of pipe-bending pliers which I've used for fuel and brakes lines on cars. They need care and some practice beforehand to use, but they do a nice job and can be used to do all sorts of funny curves in situ. This sort of thing:
Thirty quid on Amazon: https://www.amazon.co.uk/Laser-4261-Brake-Bending-Pliers/dp/B002T3XVQQ
No when bending thin wall tube the tube must be supported otherwise it will collapse.
This is done either by internal spring or plug but mostly by supporting the outside with a former.
I used to design tube making bending machines for a living lots of years ago.
https://www.cromwell.co.uk/shop/han...-8-10mm-3-in-1-mini-pipe-bender/p/KEN5886100K
I used one of these. They used to be much cheaper. Perhaps you'll find one on eBay.
Pay the postage and you can borow mine (if I can find it!).
The bending spring recomended by Vyv Cox would be cheaper, and work as well.
I use both a bender & spring for my copper work .Either will do the job. The bender is better for tight angles.
I bought a cheap bender from Hamilton Gas products & that has worked fine. Caution, do not buy a cheap eBay one-I did that first and it was so badly made, it just didn't work.
You're not supposed to use copper pipe with diesel.
It causes th diesel to form black tarry deposits..
