alt
Friends boat.... AQAD41 with DPA drives (I think).
Drive is off, bellhousing shaft needs replacing. I'm presuming this needs to be removed from the inside? (ie. the bearing pushes forward for removal) hence engine out job? If so, do you also need to remove the bellhousing or can it be done in situ?
