westernman
But you can sail at 15-20 degrees off dead down wind and sail faster than the wind speed. You boat speed adds to the apparent wind speed. This makes it looks as though a fast boat is sailing close hauled when in fact it is pointing almost dead down wind.When sailing downwind, unless you do something clever, your apparent wind speed effectively becomes the wind speed minus your hull speed or zero, if the hull speed is greater than the wind speed.
Obviously any boat can sail downwind and make it work, but if the boat gets up to the actual wind speed then there’s no pressure on the sails so everything flaps and then bangs when the boat speed drops again. Lightweight sails mitigate this by being light and hopefully not dropping quite enough to bang, but it’s still frustrating.
On a standard boat that’s fine because your hull speed is maybe 6-7 knots so you usually have sufficient wind to make it work. I don’t know what the hull speed is on Parsifal 3 but it’s certainly more than 7 knots!
Edit: it’s around 18-19 knots, so I think he had a good point.
Racing catamarans of all kinds do this all the time. Big mono hulls with a long enough water line length can sail faster than wind speed as well as planing mono-hulls such as Pogos and the new Beneteau First 30.
