bavaria 38 rudder
terryoshea
20 Oct 2004
is there anybody out there that owns a recently bought bavaria mine is only 18 months old, that has bubbles under the gel coat or worse in the laminate, my boat was pulled in july this year for its first anti-foul since commisioning in april 03 and the bubbles were discovered. please e-mail me with any info and results
dickh
8 Feb 2002
Suffolk
I would immediately contact the distributor and insist they 'remedy' the problem - if it is osmosis surely it's covered under warranty?
<hr width=100% size=1>dickh
I'd rather be sailing... :) /forums/images/icons/smile.gif
gtmoore
8 Jan 2002
Croydon
Sent you a Private Message (click icon flashing next to Main Index)
<hr width=100% size=1><font color=blue>Gavin </font color=blue>
Waypoint
5 Jul 2003
I have a Bavaria 38 which was launched in March of 2003.
It was taken out last winter and had antifouling applied and I did not notice any problems with the gelcoat. It will be coming out again at this weekend for the winter and I will check to see if there is any damage and let you know.
As a fellow owner of a sister ship of similar age, I would be very interested to hear your findings.
Lets hope it is nothing serious.
John
funnyface
5 Apr 2004
Portsmouth
We have a 1999 Bav 42 Ocean and found pinholes in the gel coat during anti-fouling in June 04. The largest holes were 3mm dia, and one was very soft around the edges. These were filled, sanded and painted, so hopefully we have caught the problem in time.
DickB
20 Dec 2002
Surrey, UK
I have a B42cc (98) and had major problems with the rudder stock rotting. Serious corrosion and had to have new rudder 2.5k!!! Suggest galvanic isolator!!! Might be worth checking. Outside of that gel coat seems fine :)
<hr width=100% size=1>Dick
branko
28 Mar 2004
Croatia
I have B 40 2001. For hull ( osmosis) Bavaria gives 5 years warranty so go ahead.
On my hull I do not see any problems. I have only a relatively strong corrosion on kiel even I cover it with epoxy primer 2 years ago.
<hr width=100% size=1>skipp
