William_H
Can someone please give me the chart again. Sorry search seemed just too hard.
regards and thanks olewill
Can I add a related question? What might explain the fact that after fully charging my batteries the resten voltage for the start battery is 12.8 and for the service batteries 12.4? Happens both when charging through the alternator + Sterling booster and using the battery charger
I put that one up some years ago (or rather, NigelMercier kindly did for me, as I was struggling to post a spreadsheet extract!). Do note that the figure of 11.0 at 0A, 40% should in fact be 11.9 - obvious really if you look at the run of numbers, but my apologies for it nonetheless.
EDIT I suppose I ought to add the usual rider about it and anything like it being just a very rough guide.
What is the difference between zero amps current draw and "rested"? And why the drop in value if there is no current draw??
I also don't understand that
The problem with the chart posted is there is no reference to the Ah capacity of the battery in question.
In the graphs in both articles posted used a proportion of the Ah capacity which has more sense i.e capacity(Ah) / 100 or some other discharge rate.
It also stated that "Resting" means when no current is entering or leaving the battery cell without and time specified so by there definition 0 Amps and "Resting" are the same by show quite different values on the posted chart
Yes, you are right about the battery capacity and my table is for about 100Ah as one of the experts pointed out - I apologize for having forgotten to add that. As I said, I have not checked the two links in detail, so if they both refer to % of battery capacity then it is likely that my table data came from elsewhere.
