RJJ
Attached photo is one of 3x 150Ah AGM batteries which I dealt with late last summer but has not coped well with the winter.
So the other two I have scrubbed the terminals and reassembled with vaseline on the outside and will keep a better eye out in future. This is the worst of the three. I have removed the nut, but the retaining bolt for the connector is firmly gripped. I have added a tiny bit of GT85 and tried half an hour later but it won't budge.
With an adjustable, it's just possible to rotate the entire connector but I am not happy putting that much force into the battery terminal. And it doesn't help anyway with the principal problem, as I still can't take the connector off and take it to bits.
Any ideas welcome. What would eat the corrosion? Is it safe to apply a heat gun? What should I do to stop this recurring? If I get it undone, do I need to replace the corroded terminal which is very pink?
Many thanks indeed.
Many thanks indeed.
