Stemar
The solar bit can be done with something like this. I had one on my previous boat. I set it to charge the engine battery until it burps, then turn its attention to the domestic system, on the basis that the engine battery's rarely going to need much, but I really want it not to be flat, while the domestic one was likely to take most of my solar for a good while. It's cheap and cheerful, but worked well. For a more efficient setup, there are dual battery MPPT controllers, like this one.Ideally I’d like solar and engine charging to all batteries in the background, regardless of switch position - sounds like that may or may not be the case…
Engine charging to all batteries just needs a VSR that will put the batteries in parallel when the alternator's doing its thing. I used a cheap headlamp relay excited by the field terminal of the alternator because my budget was tiny and VSRs were a lot more expensive than they are today.
One final thought - a question for the experts - would a VSR sensing the engine battery's voltage mean a single battery solar controller could charge the engine battery, and the VSR would pass current on to the domestic bank?
