PuffTheMagicDragon
One of my two batteries has suddenly decided to call it a day, just when I am due to leave on an extended cruise in a couple of days. The two batteries are identical and AFAIK have the same age.
The battery is marked "DELCO HEAVY DUTY FREEDOM BATTERY, Cat # 31-751, 750CCA, Load Test 370 Amps"
Questions:
1. What would be a close replacement?
2. Which standard of CCA does this refer to? (I understand that there are several systems)
3. What is the significance of the 'Load test' figure?
4. Do I look for 'Marine'? 'Truck'? Other? How many Ampere-Hours?
5. Is there a direct Delphi replacement? I ask because the Delco's were on the boat when I bought her in 1997 and the latest possible date shown on the battery sticker is '1994' - not a bad performance, I think.
6. Should I replace both?
Thanks for your time and any ideas.
Fair Winds!
Questions:
Fair Winds!
