Battery Installations.
Tranona
10 Nov 2007
One of the most frequent topics here is about choosing and fitting batteries, particularly in older boats which are going through an upgrade of the electrics. Equally popular is reports of the horrid state of electrics in many older boats, the product of starting with an inadequate original system "improved" over the years by various owners. My project Golden Hind was a perfect example. Even though everything worked it is so bad that I am ripping just about everything out and starting again. Today I completed the fitment of the new batteries. The first photo shows what I started with.
The challenge was to fit a decent house bank and a starter battery into the same space which is approx 50*50cms between the 2 fore and aft engine beds and 2 transverse mini bulkheads just in front of the engine. Keeping them all together makes wiring easier as well as the weight low down. First job was to construct a battery box out of 9mm ply with reinforcing battens underneath. the next phot shows the box which I made at home, made sure it fitted on the boat and then installed all the fittings and trialled the batteries so I knew it all worked out before taking to the boat.
Fortunately grandson visited on Sunday and made light work of humping the 2 house batteries up the ladder onto the boat and lowering them into the box. I had already fitted the start battery and connected to the engine which fired up instantly - and shut down immediately! While all this has been going on I have built a new 12v switch panel and am steadily rewiring the whole boat as well as installing new equipment. This is work in progress and I shall post a new thread when it is nearer completion.
As many know I am replacing the engine, but the new one is not due until June so the plan is to launch and motor round to my berth in the club so that hopefully I can get a buyer for the old engine while I can show how well it runs. I had considered overhauling it and keeping it, but it really is the wrong engine for the boat , badly installed and I am reluctant to spend several £k on a 20 year old engine that will always be a mismatch. I can't complete the full wiring (bus bars, switch cluster battery monitor etc) until the engine is out so I have just done a temporary job to run the engine and get power to the house circuits. That explains the rather untidy wires running across the top of the batteries in the picture of the final installation below.
The house batteries are 2*95Ah AGMs normally used on Jaguar XFs and Range Rovers. These in my view are the best value batteries on the market in this capacity range. They were £230 the pair from Tayna. I had 5 of them in my Bavaria and never gave a moments trouble in the 6 years I had the boat, serving as engine start, house and bow thruster/ windlass. From an installation point of view they are lower than any other similar battery which means there is good clearance at the top. The start battery is an Odyssey 34 Ah high performance AGM commonly used in racing cars. Similar to the Red Flash which I have used before and would have bought again except the price has jumped from £180 to £240 in just 6 months - and they were out of stock as well! The Odyssey was £165 from County Batteries. Apart from the long life the big benefit of this battery is that it fits the space which no other battery will, so avoiding building a new box in a different location with all the hassle of running extra wiring.
All the wiring (tinned Oceanflex) and fittings come from 12volt Planet. I made most of the battery cables myself using their heavy duty spring loaded crimping tool - best used with a vice to squeeze the crimps, but works OK with a hammer. BTW I have the protective boots for the terminals which I will fit when I do the final wiring. The best bit of kit I have discovered are Wago splicing connectors. In the last photo you can just see a bank of 3 2 way connectors on the outside of the box above the shunt. These are connections for the automatic bilge pump. I have used the Wagos creating mini distribution blocks, for example linking the 4 different existing cabin wiring circuits to one switch on the distribution panel. More of that later.
Hope some find this useful
Oh no, you have lost all the years of history and the vintage appeal of an old boat complete with a fabulous game of intrigue to rival Cluedo, guessing which wire does what, best played often, in the dark at sea. Hopefully all the future owners over the next 6 decades can slowly restore it to its former glory of late 20th Century wiring standards ;)
Are the batteries under the cabin sole? Presumably the box they are in is watertight from the bilges? Unlikely I know, but what happens if a large amount of water suddenly comes down the companionway? Or a spillage from the galley?
Yes, under the cabin sole and the bilge sump is just behind. Not uncommon in the day, and still common in modern boats. You can play "what ifs" all day long, but well over 250 boats of this design were built, the majority with this battery arrangements. At least 50 did transatlantics in the 70s and 80s and many have circumnavigated so I don't think I am in danger when pottering up and down the Dorset coast!
Seriously if one were starting from scratch there are better places to locate the batteries and I did think of moving them to the locker under the head of the quarter berth, but that is where I want to locate the B2B charger for the windlass battery and the mains charger. There is not room for these plus the batteries in this locker and it would be a lot of work to build a robust battery box there. Anyway, hopefully by the time I have finished the boat will be a "dry" boat. While the engine is out will be able to get the sump emptied completely cleaned and painted. Cured all the leaks from the top so far, will be fitting a proper dripless shaft seal, the cockpit is a GRP moulding and self draining with a high bridge deck so hopefully I can get it as dry as my Bavarias were.
TG being wooden, I had the batteries where they were. One year, on launch I had a leak, a bad leak and she needed a professional pump to keep her afloat. I slept on board to monitor the leak. I tried to sleep so I turned off the pump and and I slept by dangling a bare foot on the cabin sole to wake me to turn it back on. But then if batteries were au bilge - eek. Oh the benefit of gliberfast. :)
Fortunately my boat has a GRP hull and wooden top. Automatic bilge pump that works. Bit different from my old Eventide with an open non selfdraining cockpit and a leaky Stuart Turner dribbling petrol evry time it was used!
Fyi. I have a 1.5kw bow thruster working off the start battery. No probs. 70mm cables. Nic 31.
The bow battery was already there - recently installed for a Lofrans windlass. initially a bit of a mystery how it was charged, but eventually discovered lightweight wires from the solar panel and wind generator both of which I have removed. Now will charge from a B2B off the start battery which needs only 10mm cables. Not a lover of driving a thruster (or a windlass) from the start battery and certainly not from the one I have. Prefer dedicated battery for each major consumer. Most people fit far too big a start battery for small engines. With modern diesels they get very little use and are recharged quickly. I may fit a bow thruster if she proves too much of a handful berthing and will run that off the existing 105Ah bow battery.
Not sure there is anything to vent - they are sealed AGMs and the Odyssey can be mounted in any orientation, often mounted on their side in emergency vehicles. Batteries are commonly located in open under berth lockers without any problems. Don't think I have ever seen a sealed battery installation with a vent such as you describe on a yacht.
I have a massive Odessey as my house battery. They do have an overpressure vent hence my suggestion to vent the box. Also if you have a sealed box then changes in atmospherics could compromise the seal. Although not common a sealed box in a low installation gives you the possibility of the electrics still working when the bilge is full. So you get to have an electric bilge pump running to buy you some time and a radio working to buy you an escape plan.
The lowest exposed electrical positive in my boat is on the engine starter. By the time that is submerged she would no longer have any buoyancy so I would be making my exit stage aft. Until then all my electrics would still work.
Maybe you haven't seen seal battery boxes but I bet you've seen or heard of lost electrical systems due to flooding, Zingaro springs to mind.
See post #5. This boat is an old fashioned east coast originated pottering boat that happened to hit the spot for ocean voyagers. One can imagine all sorts of things that "might" happen and if one wanted to create a perfect boat that could cope with every eventuality you would not be starting from where I am. The boat has been in regular use for over 40 years and no sign that it has ever sunk (like 99.9% of boats) so don't think it is likely to happen in the 5 years I expect to own it.
BTW I don't think the Odyssey I have does have a vent, although the Exides probably do - but the chances of them ever venting in the type usage I shall give them is close to zero. Even if they do plenty of space for any gases to dissipate.
