Drascomber
I have a popular make of switch panel that incorporates a little vertical meter which is supposed to indicate the condition of each of my batteries when I throw the provided switch to either 1 or 2.
Whenever I use this the needle always goes in the green direction to full deflection. Usually this is what I expect as my battery usage is normally very low. However, I recently used the tiller pilot for days without running the engine - until the device stopped working because of low voltage. I took the batteries home and measured 11.5 volts i.e. both batteries totally flat. (BTW I don't have electric engine start and on this occasion running both batteries together)
But the Battery condition meter on the panel still went fully to the green end for each battery.
It is possible I have wired the thing up wrongly or is it a bum meter?
