Battery Charger
z1ppy
9 Mar 2008
New Forest
Afternoon.
Simple question i am sure.....
We have 3 batteries on Aviator and one of them clever charger things that switches from float charge to actual charge when its needed (Victron Phoenix i think)
Boat is hooked up to shore power. tube heater in the engine bay is running direct from the boat using the shore power. (no battery drain)
Should i leave the charger on all winter allowing it do decide when they need charge or is this going to knacker the batteries??
Having spent £££ on new Rolls batteries last year i kinda want to make sure they last the winter at least!
Thanks in advance.
Hi Howard
sounds same to my set up, last owner spent a fortune on a Victron charger and separate inverter for Seabird just before he sold it. So as yours and most modern chargers they do go onto a maintenance charge rate once the batteries are full, but if you are not using the boat then I see no reason to leave it on. I turn mine off. The only thing that I leave on which is on battery circuit is the bilge pumps, but (so long as they are not working! :eek:) all i am powering are 2 tiny led lights. If your batteries are in good condition they will maintain their charge.
With the boat out the water since Nov & battery charger off & I have been down a couple of times, each time batteries still showing 12v...
I do also switch off at night when we are on board as the charger is located near my daughters berth and it is audible with a very small fan cooling the electronic gubbins... all of which will draw electrics which you will be paying for..
IF the battery is showing 12 V, that means it's vurtually dead.
For my part, I'd leave the batteries charging all winter on a smart charger, the only other option being, to let them drain down till dead.
if you have the Victron charger, it doesn't harm to leave that one on,
I't won't damage the battery's from overcharging
each time when you discharge the batt. under 80% you reduce its capacety / livetime by a certain percentage.
even a tiny load; alarm, controll light, relay,.... will discharge the battery
I know that some people are afraid for potential risk of fire leaving the battery chareger switched on all the time, .....
I'm willing to take that risk.
Yeah ok hlb.. its showing something over 12v...as my voltmeter is a needle & not digital readout I didn't give exact. Enough to start engine which at the end of the day is what I need...
I believe the victron charger is one of the best, and so it does have a maintenance level of charge which will do what it says & I guess may maintain there longevity? I just don't like leaving electrics like that switched on when I leave the boat... but that is obviously just me.
I leave mine on charge any time the boat is plugged into shore power.
Leaving batteries standing for a long time, especially over Winter, can discharge them enough to kill them. Most people with things like jet skis, motor bikes, etc will put them in the garage on a smart charger over Winter, or have to buy a new battery every Spring.
My Battery has a maintenance top up charge once every week, through out winter, i also test the gravity electrolyte levels and and top up with distilled water, a constant charge on the battery will required the levels to be topped up.
Please remember it not just volts which is important, it the amps testing gravity will give you a better idea of the condition and charge of the battery a 100% charged battery should give a reading of 1.265 gravity 75% charged battery will give a reading gravity of 1.239 but outside temp will alter the reading slightly.;)
mark
