help ,in a senior moment i cant remember what a battery charger for shore power is called,and if you have any idea of a good suplier that to would be usefull,thanks.Kieron
There is a differance, for years we supplied Sealine with battery chagers, they charged up to 14.3 volt. But as all the other builders were fitting simple 13.6 volt chargers, Sealine followed suit, these were called shore support.
So a shore support provides power when shore AC is available at a float voltage, a battery charge goes to high voltage to charge a battery, then goes to a float support voltage.
I have a Sterling fast charger and I think it does just what you want, once the batteries ar charged up, it supplies all the 12v I need without touching the batteries.
"Battery Chargers" have what is called "Power Pack" mode or function
A new name for float charge mode.
Brian
Just found the instructions for my Sterling ProCharge - the POWERPACK functions is described as "Full current is available for on-board supply" during the float stage.
Brian
John
Thats what I said, the charger's we built back in 1985 supplied full power in float mode for domestic loads.
The wonders of modern marketing /forums/images/graemlins/smile.gif
