macd
I do leave my battery charger on and can safely say it should consume hardly anything.
1.5 units is about 25pence per day or thereabouts . Not huge but perhaps fridge has been left on?
Has a frost protection heater not been put in the engine bay ? if so it might have cut in in recent nights if on a thermostat? Perhaps frost in your area is not a risk?
Starting the engine every few weeks also seems to me unnecessary and possibly detrimental …………but each to his own,.
Even if fitted, I very much doubt any frost protection has kicked in. Still mild on most of the Turkish coast.
The engine start routine suggests the engine hasn't been winterised, in which case some manufacturers recommend running the engine every few weeks.
Further to my post above I called the marina electrician to the boat. He confirmed the units on the meter are a tenth of a Kw so the 15 per day it's using = 1.5Kw. He didn't seem to think the usage was unusual but he wouldn't, would he.
Consumption meters are not calibrated in kW, but in kWh (kilowatt hours), i.e the "volume" of electricity used. Whatever the sparks says, 1.5kWh is unusually high if the battery charger alone is drawing power. For comparison, charging the 2 x 225Ah batteries from half discharged would take roughly 3kWh, less efficiency losses. Clearly that's a whole lot more than the float charge they should need to keep them topped up.
