Dave_Knowles
Hi,
I am confused as to what size my battery cables should be. At the moment they are I believe welding cable and need to be replaced. My starter motor which is 0.8kw I understand is the key to the size. I have a new alternator which is 60amp and two 110 amp batteries one for starting. These are through a switching unit. The engine is a Volvo AQ151 rated at around 120hp. I do have some new cable which is 50mm sq but is this too heavy? Also I am having trouble putting on the crimping ends if I do use this as the wire seems too big although I am assured that the terminals are for 500mm and they have 50-8 on them.
Dave
<hr width=100% size=1>http://stores.ebay.co.uk/mycleopatrachandlery
Dave
