Well, if we're having a pic waving contest, here's one with proper coloured cables![]()
One of those +ve connections looks very much to me like a black cable with red heat shrink.
Richard
If there's one thing i really hate, it's using all one colour cable, with heat shrink on the ends !
Richard
You think it should be red cable with black heat shrink on one end Richard![]()
May I ask why?If there's one thing i really hate, it's using all one colour cable, with heat shrink on the ends !
Errrrrr ... how about red cable with red heat shrink for the +ve cable ..... just like the other +ve cable?
Richard
May I ask why?
7.8.3 All d.c. negative conductors shall be identified by black or yellow insulation. If the craft is equipped with an a.c. electrical system (see ISO 13297) which may use black insulation for live conductors, yellow insulation shall be used for d.c. negative conductors of the d.c. system. Black or yellow insulation shall not be used for d.c. positive conductors.
Interesting point.
In a series installation what's the best way of identifying/differentiating a neg cable from a pos ? Or are the final connections to/from the bus bars (etc) the only ones which need colour coding ? Should the + to - connections between series batteries be given a different colour with lecky tape ?
It looks as if I will be going for black cable only, with red heatshrink on the + terminals, and red tape at intervals on the + cable on long runs. One cable colour only in the electrics box sounds a logical logistics solution ?.
That wouldn't work at all Richard. Those two batteries are wired in series, for 24v, so that cable is connected to a +ve at one end and a -ve at the other![]()
I am not working in the industry. I am working my own small yacht.Positive cables should be easily identified by their colour, as should negatives. Once you get a short distance from the batteries you have no idea which is which. So it's best practice not to use black for positive cables. Just last week i had to do some repairs on a charging system that a "professional" installer had wired using all black cable, it made the job much harder to fault find, where you could normally see which wire was which (to a degree) it was completely impossible with this setup, every wire had to be identified by testing it.
Anyone working in the industry, in an area that is regulated and required to follow the ISO, would be required not to use black for positive conductors.
[/B]
Regarding "best practice". One of the best practices I know of in engineering is the application of common sense.
Errrrrr ..... it's bloomin' obvious that the batteries are connected in series.![]()
Which surely means that the +ve cables are the cables (two in this case) attached to the +ve positive output from the bank?
Unless I'm misunderstanding the photo, I'm not sure why this is becoming such a struggle.![]()
Indeed, that's why we use red for positive and black for negative :encouragement:
Where necessary, ie at the cable terminations.![]()
Only if you're inventing a new way of doing it
It's your boat and you could wire it up with yellow and pink wires or any other colours that you like the look of. But, there is an accepted standard that is known and understood by just about everyone, so i like to stick to that.
Although i'm doing it professionally i'm not required to follow the ISO, but it does all make sense. The next person working on a conventional installation will understand how it's wired. It may not apply to your own installation, but cables invariably pass through bulkheads or are contained within trunking, you can't see both ends and it makes extra work identifying which is which, whereas proper colours are easy to spot.
You're obviously happy with it and it certainly won't impair it's function, but i still hate seeing it
Another pet hate is when people add wires to a harness and cable clip along the harness without removing the existing cable ties Grrrr
Is it because you are mistaking the rather old windlass cable, which has gone a luverly shade of very dark red, almost brown, for a black cable
Apologies for not spotting what you were talking about sooner. :redface-new:
